Error -10007 after self calibration
I am trying to self calibrate an AT-MIO64E3 using 'Calibrate_E_Series'
under CVI5.0. After the calibration using 'SCAN_op' I regularly (not
always however) receive the error message -10007:
"Channel out-of-range for device type or input configuration; either the
combination of channels is not allowed, or you must reverse the scan
order so that channel 0 is last"
Any hints would be appreciated.
Thanks, Matthias
Sent via Deja.com http://www.deja.com/
Before you buy.
Message 1 of 1
(2,734 Views)
