Error -10805 occured at AI Buffer Read
Possible reason(s) (as shown in Labview):
NI-DAQ LV: The clock rate is faster than the hardware can support. An attempt to input or output a new data point was made before the hardware could finish processing the previous data point.
The condition may also occur when glitches are present on an external clock signal
Hi everyone,
is someone familiar with this error?
The software was running for 15 years with no problem
The PC is WinXP
Thank you
(2,025 Views)
Is the suggestion plausible?  Are you using an external signal as a sample clock?  Maybe there could be a loose connection, leading to an intermittently glitchy signal.
If your device is making its own sample clock internally, then I don't know.  I suppose I'd wonder about some failure or damage within the board.  No proof or anything, but 15 years *is* a pretty good run, nothing lasts forever.
-Kevin P
(2,002 Views)
