Error - 10805 & others on PCI-MIO-16-4E
I recently started getting this error when running an application that has run perfectly in the past. I tried looking at the device using the MAX Explorer test panel and "Test Resources" under device properties and also received the following errors:
1. The device is not responding to the selected base address.
2. The device is not responding to the first IRQ level
3. The device is not responding to the first DMA channel.
4. The device also passes frequently...
The test panel flashes error - 10805
There are no inputs connected to the DAQ
Any ideas what I may have done to the system/card to cause this?
Cheers
Nathan
(3,173 Views)
Hello Nathan,
Thank you for contacting National Instruments.
I am not sure what version of the NI-DAQ driver you have installed, but I would like you to download and install our latest release. Here is a link to the driver:
http://digital.ni.com/softlib.nsf/websearch/C1F802E457EA042586256DD00001B0C9?opendocument&node=132060_US
Before you install the driver, remove the board from the machine. Then install the board in a different PCI slot than the previous and boot the machine.
Check to see if the board appears and works correctly in MAX. Let me know if you are still experiencing problems and I will determine a new course of action.
Bill B
(3,173 Views)
I am having a similar problem with a PCI 6052E (Device not responding to the selected base address...)  It worked fine several months ago and when I tried to use it recently I get this error.  No changes were made in the meanwhile.  I have downloaded and installed the most recent drivers (7.4.4) and receive the same error in MAX.  Any suggestions?
(2,708 Views)
