Error 10845 on DAQCard-AI-16E4
I run LabVIEW 5.1 in Win95. My notebook has 64MB RAM and CPU Pentium II
300. I'm trying to update 16 kanal and write to file (scan rate - 1000
S/s).I use "flush.vi" in my aplication. I'm getting error 10845 overflow
after a few seconds. How can I avoid this error ? I have to use faster
scan rate (3000 S/s).
Darek Downar
(3,411 Views)
Dariusz,
Upon doing a search for "10845" at NI's KnowledgeBase site, I found the
following entry that does a good job of explaining the situation:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/ef97e24b4580540186256555006a8a5d?OpenDocument
Simply put, it is an issue of PCMCIA architecture having no DMA
support. If there is anything you can do to lift the load off of your
processor (w/ respect to IRQs), it would improve the situation.
Rich Yavorsky
NI
Dariusz Downar wrote:
> Hello,
> Thanks
> Darek Downar
(3,411 Views)
