I'm using a 6041E board with LabVIEW 6.1. I have an application which was working fine for months. Now, for no apparent reason, I'm getting "Error -10845 occurred at AI SingleScan". Nothing has changed in my application. Same number of channels, same scan rate. Interestingly, I tried lowering the scan rate from 10K samples/second to 100 samples/second and the error went away. It comes back for anything over 500 samples/second. What in the world could have happened?
