Error -200019 occurred at DAQmx Read (Analog 1D Wfm NChan NSamp).vi:2
I want to use the program to obtain the signal from the 1kHz laser
but I can not do it, the error message is as below:
Possible reason(s):
Measurements: ADC conversion attempted before the prior conversion was complete.
Increase the period between ADC conversions. If you are using an external clock,
check your signal for the presence of noise or glitches.
Task Name: _unnamedTask<4>
my sampling rate is 30000 and number of each sampling is 10.
Message 1 of 8
(4,096 Views)
Chien-Feng,
What hardware are you using?  Which version of DAQmx are you using?
Dan
Message 2 of 8
(4,090 Views)
Sorry! i am not in the lab !
i will find out your question soon
thanks a lot !
Message 3 of 8
(4,080 Views)
Dan
I am using the NI 6230 , but I don't know what  is the hardware
Thanks!
Message 4 of 8
(4,064 Views)
Chien-Feng,
Since you're using the 6230, I don't see anything obviously wrong with your setup.  Do you see this error consistently, or does it happen sporadically (by this I mean does it happen at the same iteration of the top while loop)?  What is the nature of the signal that you're connecting to PFI 0?
Dan
Message 5 of 8
(4,059 Views)
PFI 0 is the trigger voltage about 5 V
Message 6 of 8
(4,046 Views)
How frequently do you recieve triggers?
Message 7 of 8
(4,043 Views)
About 1kHz
I am doing the laser experiment.
Because the frequency of laser now is 1kHz.
However, this Labview program was previously used to 82MHz laser.
So, is the sampling rate too high? or number of each sampling too much?
Thanks!
Message 8 of 8
(4,039 Views)
