04-12-2008 07:39 PM
04-14-2008 12:43 PM
If there is any question about whether or not the board is damaged, you can run the E Series online diagnostic utility. If the diagnostic utility fails any of the tests, there is a good chance the board needs repair. If this is the case, generate a service request at ni.com/support so you can send your board in to be fixed.
Regards, Mallori M.
