Error -200077 USB X Series
I have problem with USB X Series 6343. When i try use triggering block i get following error
Message 1 of 10
(6,162 Views)
As the message and specs say, you only have digital triggering so specifying an analog trigger is not correct.
Message 2 of 10
(6,150 Views)
So, can you help me how can i digitizing analog signal ?
Message 3 of 10
(6,145 Views)
That is unclear. Do you simply want to immediately acquire an analog signal or do you want start an acquisition from a trigger?
Message 4 of 10
(6,141 Views)
First of all of course to acquire a digital signal (because 6343 support only digital signals but i have analog) and then start an acquisition from a trigger.
Message 5 of 10
(6,131 Views)
Connect an external comparator to the signal you want to trigger off of.
Message 6 of 10
(6,128 Views)
I should do this in Labview 😃
Message 7 of 10
(6,117 Views)
No, you should do it with an external comparator. That means hardware.
Message 8 of 10
(6,108 Views)
Ok, got it. Thanks.
Message 9 of 10
(6,103 Views)
I am hesitant to even mention this... but if you acquire continuously you could determine when the trigger condition is met in software and only keep the data you are interested in.
There is an example that does this:
https://decibel.ni.com/content/docs/DOC-11764
Best Regards,
John Passiak
Message 10 of 10
(6,086 Views)
