Error -200077 when trying to generate analog output signal
I am trying to generate output signal using DAQ assistant to a power amplifier that will be connected to an electrodynamic shaker.I am using NI USB4431.I have inserted 5k in the samples to write box as this shows a suitable movement of the shaker if I run it using DAQ assisstant. But once I try to run the program from Labview, I am getting an error message:
Error -200077 occurred at Untitled 1:Instance:1:1,Possible reason(s):  Requested value is not a supported value for this property.  Property: SampClk.Rate You Have Requested:  1.0e3 You Can Select:  800.000000,  1.250000e3,  1.500000e3,  1.600000e3,  2.500000e3,  3.0e3,  3.200000e3,  5.0e3,  6.0e3,  6.400000e3,  10.0e3,  12.0e3,  12.800000e3,  20.0e3,  24.0e3,  25.600000e3,  40.0e3,  48.0e3,  51.200000e3,  80.0e3,  96.0e3.
I do not know where to change the sample clock rate, I have attached a printscreen of the DAQ assistant configuration window. Really hope you can help.
Message 1 of 1
(3,062 Views)
