Error -200077 with cDAQ Strain Bridge Nulling and Temperature on 9219 Module
We are measureing a Thermocouple + 2 Full bridge stain sensors with a 9219.  When I run the Bridge Null fucntion, I get:
DAQmx Perform Bridge Offset Nulling Calibration.vi:3<append>
<B>Property: </B>SampQuant.SampPerChan
<B>Requested Value: </B>1
<B>Valid Values Begin with: </B>2
<B>Valid Values End with: </B>8589934590
<B>Device: </B>cDAQ1
<B>Task Name: </B>_unnamedTask<6B>
This KB article mentions the problem was fixed for SCXI on DAQmx 8.9 or so.  I am running 9.3.5.
Any ideas?  Will I just have to not use the CJC?
(2,869 Views)
Hi Jed,
Would you post the code that you are using? I would like to reproduce the error.
steve.bm
AE | NI
(2,854 Views)
