Error 200099 on new windows 10 comp
I recently purchased a Dell 3420 PC, a 9174 chassis, 2 9401 I/O modules and a
9234 module.  Once the PC (running W 10 pro) was received the latest version of DAQmx was downloaded (16.0.1f0 December 2016) and installed.  When I try to run my software I get an 'physical channel not specified' error.  I have the same code
running on a 2nd computer with a different set of hardware (same models)
and everything works fine.  I swapped the 2 computers and the problem stays
with the computer.
(3,098 Views)
Hey Alan,
Is the hardware listed in the exactly the same way within MAX for the 2 setups that you are working with? It could just be that the devices are listed differently in MAX for the two different setups.
Shezaan Noorani
(3,031 Views)
