Error-200170 channel specified does not exist
While using N.I. Data Logger with a N.I. USB-6008 DAQ, I am now seeing the folowing error code:
Error - 200170 occured at Physical channel specified does not exist on this device
I am perplexed as the device has been used for this application before, as we normally use all 8 analogue inputs.
Can anyone Help?
(4,504 Views)
Is your USB 6008 showing up on MAX??
Is the Physical channel you assign to it match with its device number in MAX?
Regards
Dev
(4,488 Views)
Hi Hugh,
I believe we may have been talking about this issue over the phone. By switching the USB device support for this device over to NI-DAQmx via MAX should resolve the issue. VI Logger Lite would have to be used instead of the DAQmx Base datalogger you have been using up to now.
I hope this helps,
Rob
National Instruments | Northern California
(4,467 Views)
