Error 200273 -NI USB 6001
I'm new on NI world, I bought an NI 6001 USB for a simple application that requires and analog signal generation.
I'm trying to get familiar with this new HW but I get an error 20073 while running "Continuous Tone Generation and Finite Acquisition (Regeneration)" example for Signal Express.
I googled without success, can anyone help me to solve this issue?
Thanks in advance for your help,
Antonio
(4,362 Views)
Ciao Antonio,
potresti inviarmi lo screenshot dell'errore?
Cordialmente,
Valerio
(4,328 Views)
Can you supply some code?  That error code just says you tried to set two values that conflict.
GCentral
(4,322 Views)
@Valerio,
nel file Error.jpg in allegato puoi trovare lo screenshot dell'errore che viene visualizzato.
@crossrulz,
it's not code. As you can see on screenshot Error1.jpg attached, it's just an example loaded from SignalExpress library.
Thanks to both for your help.
Antonio
(4,310 Views)
