Error 200279 with low sampling rate
we are using the NI6008 with a fermentor.
We are using DAQmx read with a sampling rate of 1/60 Hz (every minute one sample). Samples to read 1. Continous samples.
But we still get after some time (about 5 hours) the error 200279.
I do not know why we get this error with such a low sampling rate.
The program should have enough time to get to samples before they are overwritten.
Any suggestions?
Thanks alot!
(2,988 Views)
Using continuous sampling with a single sample and long delays seems a bit silly to me. Switch to N Samples or On Demand. You are essentially doing on demand anyway.
(2,986 Views)
