Error -200284 ocurred at DAQmx Read (Analog 1D Wfm NChan NSamp).vi:2930001
I was trying to run the Finite Measurement DAQ-mx template project, but sometimes when i want to acquire signals from a NI cDAQ-9172, i get this error: "Error -200284 ocurred at DAQmx Read (Analog 1D Wfm NChan NSamp).vi:2930001".
The part of the code responsible for the acquisition can be found at "Acquire Data from Hardware.vi":
I remeber using the same code in Labview 2013 and it worked just fine. Rigth now i have Labview 2014 and DAQmx driver installed.
What could be the problem?
Pedro
(6,580 Views)
How much is sample and sample rate? Which analog card are you using?
PBP
Labview 6.1 - 2019
(6,563 Views)
I'm using a cDAQ-9172 with one NI 9215 module.
As for the sample rate and number of samples per channel, i've used 10000Hz and 5000 samples. I've tried different values, but i keep getting this error.
(6,560 Views)
How much time out you have kept in analog read VI?
What is your application? I mean are you continuously aquiring?
PBP
Labview 6.1 - 2019
(6,539 Views)
If you are only using 1 channel, you should be using the 1 Channel N Sample Waveform instance of the DAQmx Read.
(6,532 Views)
I'm using the applicattion included in the attachment to do a finite acquisition.
I've tried to acquire 5000 samples from 2 signals at 10kHz.
This error does not happens all the time. The first time i make an acquisition, i get this error, but in the next attemps the error appears to be random.
I also experimented with higher frequencies and lower number of samples, but the error continues to appear.
Pedro
(6,487 Views)
I have the same problem with elvis II, How I can understand the problem is the buffer size of the device. It won't flush measurement via USB port, and gives this error after a time. I think solution can be emptying buffer frequently
(4,880 Views)
