Error 200288
I am trying to write a program in labview using USB 6211 as my Daq card to achieve the following:
I need to output a constant DC voltage of 5 V if my input voltage is less than 3.
Output -5 if my input is greater than 7.
 output same as before if input is >3 and <7.
I have the case structures all set ,but I am getting an Error 200288 which has something to do with loop execution.
I have tried a few of the solutions found in the forum,but have been unable to  solve the problem.
I am attaching the code. Testing feedback.vi is my mail program..untitled8 and untitled4.vi are also required to run this program i think.
Thanks and regards ,
 Karthik Jay
Message 1 of 10
(7,309 Views)
You didn't attach your code.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 10
(7,307 Views)
oops.. sorry..
Message 3 of 10
(7,299 Views)
You have complicated your code by using regeneration when you actually don't need it and have not taken the necessary steps to address it. Have a look at the attached code (I just generated one by using the DAQmx examples). Hope it helps!
Adnan Zafar
Message 4 of 10
(7,295 Views)
Hey,
I am unable to open the VI since I am using Labview 8.5 and you are using 8.6.
I would be greatful if you can save them with the previous version and post the VI again.
Karthik
Message 5 of 10
(7,289 Views)
Sure. Saved in LV 8.0.
Adnan Zafar
Message 6 of 10
(7,286 Views)
Accepted by topic author karthikj85
I have one last problem here.
I have to get 2 input signals to the VI.
One of them runs thru the case structure and the other just has to be displayed.
I copy pasted a few sub vis and tried to run it.
However i am able see only one signal being read. I have attached the VI .
I am really grateful to NI for such a great customer supprt system.
You saved me a lot of time and effort with your help and guidance.
Thanks people.
Message 7 of 10
(7,259 Views)
You've made a very common mistake. You CANNOT have two separate tasks that use the same resource. Combine your analog inputs into a single task. That means only one DAQmx Create Channel and only one DAQmx Read.
Message 8 of 10
(7,257 Views)
OK. thanks.
I now have both the Create Channel .vi in series .
I changed the DAQmx read.vi for Multiple channels>>Multiple samples>>2D DBL
Now i need to seperate the two inputs ,perform the logic operation on one and just display the other.
Could you give me info /link on how to do that?
Karthik
Message 9 of 10
(7,250 Views)
ok. i used array indexing and got the values out.
Thanks..
Message 10 of 10
(7,241 Views)
