Error 200303 & Error 200288
Hi there,
In the attached VI I am trying to collect 4 Analog IN channels when it detects a rising edge on a Digital Line for finite samples. When the state of the Digital line goes from high to low, I trigger a Analog out on the falling edge and it outputs finite samples before going to the next loop iteration of the while loop. When I try to debug the program using Highlight execution I get the error 200303 and when I do not use highlight execution I get 200288. Please advise. Cheers, Biswa
(3,080 Views)
Hi
I have just tried to run your program and I do not get the same error, so do you know at which VI the error occurs? Does the error popup during program execution or at the end of the program?
Can you also tell me which card you are using?
Regards
Beejal S
NI UK & Ireland
(3,042 Views)
