Error -200361
Hello All,
I have a simple C application where I read every ms the actual value of a Digital Input in a CDAQ NI - 9375 module.
My Rack is a cDAQ-9178 connected with USB conection to a Win 7 PC.
My application does in this order:
DAQmxCreatetask
DAQmxCreateDIChan (2 times one per channel)
DAQmxCfgSampClkTiming
DAQmxSetReadOffset
DAQmxSetReadRelativeTo
DAQmxStartTask
DAQmxReadDigitalLines
What happens is that when I read the Digital lines I get the erro "-200361 - On Board device memory overflow"
The parameters Im using are like bellow:
Function Parameters
DAQmxCreatetask -
DAQmxCreateDIChan
lineGrouping DAQmx_Val_ChanPerLine
rate 10000
activeEdge DAQmx_Val_Rising
sampleMode DAQmx_Val_ContSamps
SampsPerChanToAquire 1
DAQmxSetReadOffset
  0
DAQmxSetReadRelativeTo DAQmx_Val_MostRecentSamp
Start Task -
numSampsPerChan 1
timeout 10
fillMode DAQmx_Val_GroupByScanNumber
readArray @val[0]
arraySizeInSamps 2
If I try to change the "offset" to a negative number (dosen't matter if -1, or -10000) I get another error: "-200277 - Invalid combination of position and offset"
What am I doing wrong?
(4,363 Views)
Hello aranteg,
did you also test the shipping examples ?
maybe you did not collect the data from your onboard memory that causes an overflow
or you are have to much records in a short time which is also causing an overflow on the card
Stefan
(4,335 Views)
