Error 200430
I am using USB-6008 and I keep getting error 200430 with the following code and I was curious as to why.  thank you very much for your help.
int
error=0;
int32 sampsPerChanRead;
bool
thread;
TaskHandle taskHandle=0;
// Analog Output
TaskHandle taskHandle1=0;
// Analog Input
TaskHandle taskHandle2=0;
// Digital Input
float64 data[10000];
float64 Range[3] ={1.5,4.0,9.9};
float64 temp[2000];
float64 trianglewave[1000];
float64 FlowData[1000];
char
errBuff[2048]={'\0'};
char
output[1000];
CPaintDC dc(
this);
CString str = "top";
char
tempstr[10];
int32 written;
int
i=0;
// Initialize Card
DAQmxResetDevice ("/Dev1/");
for(;i<1000;i++)
data[i] = 4.9*(
double)i/4000.0;
/*/ DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ai0","",-5.0,5.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
/*/ DAQmx Write Code
DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL));
/*/ DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
(5,384 Views)
Look at the type of channel you are creating (AOVoltageChannel) and the name of the channel (Dev1/ai0). You need to match CreateAOVoltageChan with channels named 'ao' and you need to match CreateAIVoltageChan with channels named 'ai'.
(5,371 Views)
