Error 200524 in DAQ 6216
Thanks Seth, Thanks a lot for your help.
Regards
Himanshu Nagpal
Message 11 of 14
(1,125 Views)
Hi Seth,
One last question, is there any way in which i can add how many switches you want to use? I want to make program it in a way it is  generalise for all cases. If user enters 5 it runs first 5 ports and if choses 32 ports it runs 32 ports or 10 ports it runs logic for 10 ports and ignore rest.
Thank You
Himanshu Nagpal
Message 12 of 14
(1,119 Views)
You can use the "Array Subset" function.  It will look something like this:
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 13 of 14
(1,117 Views)
Hi Seth,
Sorry, I have a question again. Actually I am trying to write  it in a text file and table. I want when it runs first time it write temperature and power meter reading for switch1, switch2, ....(so on) ( which ar nothing port1, 2,..  I have just givn them a name of switch1,2..) untill it reaches no. of ports( in array subset) which we will be using. and then outer for loop works it keep updating under sitch1, switch2,---so on.
I made a logic but what it does is it writes under switch1 and temperature. So can you guide me what can I do here?
Thank You
Regard
Himanshu Nagpal
Message 14 of 14
(1,103 Views)
