Error 233902 occurred in the self-test with PXI-4072
Greetings ... I commented that a couple of days ago I have the following problem with the PXI-4072 (image attached). Previously this instrument worked very well, but that was almost three months ago. I have mounted the PXI-4072 in the PXI-1042 chassis and I have installed the NI DAQmx 9.2.3 and the NI DMM 3.0.6. Someone who can help me with this problem please. Thanks in advance
(2,503 Views)
Hello Cesar182,
It seems that your DMM is damaged and you should send it in for repair. Call your local NI office (found on the bottom of this page) to begin this process.
Fernando Becerra | Field Applications Engineer | National Instruments | CLA | CTD
(2,480 Views)
