Error 50103 by using 9229 to collect data
I use 9229(usb casing) to collect data by attached vi.
But got error 9229 as attached, any suggestion?
Message 1 of 8
(4,087 Views)
Hi Turbot,
Thanks for the post and I hope your well today.
It is generally good programming practice to only have one AI/AO DAQ task. I would use one task, and use ai1:3 and see if you still get an error or not.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 2 of 8
(4,075 Views)
May I know how to use ai1:3, thanks.
Message 3 of 8
(4,060 Views)
Accepted by topic author alex.
You use it just like that. Instead of Dev1/ai0, use Dev1/ai0:3. Simple.
You can do the same thing by clicking the little arrow on the right side of the physical channel constant and selecting Browse. Use Ctrl-Click or Shift-Click to select your channels.
This is probably covered in the Getting Started with DAQmx tutorials.
Message 4 of 8
(4,056 Views)
I tried to click on it , but still can only select one channel as screenshot, any suggestoin?
Message 5 of 8
(4,047 Views)
Did you not read the part where I said to select 'Browse'?
Message 6 of 8
(4,044 Views)
Yes, I use the browse and get 4 input as the screenshot as http://forums.ni.com/ni/attachments/ni/250/45494/2/shot.JPG
But when running it, got error 50103 said cannot run at same time.
Message 7 of 8
(4,038 Views)
Thanks, I have used shift key and done it.
Message 8 of 8
(4,034 Views)
