Error 50103 while combining heater control with larger program
I have made a block of code that controls a heater.  This block of code works fine on its own, but when I try to copy it into my main program I get Error 50103.  I know that this is because I have the DAQ Assistant acquiring data as well as the heater code, but I'm having trouble combining them together.  I can't get the heater control to work with a temperature acquired through the DAQ Assistant.  How can I successfully add this heater control to my main program?  I've attached a copy of my program below.
CJones581
(3,065 Views)
Since you seem to configure two (or more) of tasks for the same resource, you will have to redesign your vi such that the channels in the two seperate tasks will be merged to be referenced by a single task.
(3,057 Views)
