Error -50152 Linux Ubuntu
The PCIe-6363 board I have works without any issues in my PC when I boot up in Windows. The M&A program and all my C++ code works great. However, when I boot up in Linux Ubuntu 24.04.1 LTS, I have some problems. For example, my C++ code works until it gets to the DAQmxStartTask command, and then I get error -50152.
I can replicate this error when pressing the Self-Calibration button in the Hardware Configuration Utility. A pop up window gives me this error:
Error Self-Calibrating Dev1
The device could not be calibrated.
Status Code: -50152
A hardware failure has occurred. The operation could not be completed as specified.
Interestingly, the Reset and Self-test buttons both work fine.
Any thoughts?  The NI packages that I have installed is listed below (copied and pasted from the terminal window):
ni-apal-errors/unknown,now 24.8.0.49244-0+f92 all [installed,automatic]
ni-avahi-client/unknown,now 24.8.0.49237-0+f85 amd64 [installed,automatic]
ni-bds-dkms/unknown,now 24.8.0.49244-0+f92 amd64 [installed,automatic]
ni-bds/unknown,now 24.8.0.49244-0+f92 all [installed,automatic]
ni-ceip/unknown,now 24.8.0.49248-0+f96 amd64 [installed,automatic]
ni-controllerdriver-errors/unknown,now 24.8.0.49267-0+f115 all [installed,automatic]
ni-controllerdriver-libs/unknown,now 24.8.0.49272-0+f120 amd64 [installed,automatic]
ni-controllerdriver/unknown,now 24.8.0.49272-0+f120 all [installed,automatic]
ni-daqmx-dsa-libs/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-dsa/unknown,now 24.8.0.49497-0+f345 all [installed,automatic]
ni-daqmx-ef/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-errors/unknown,now 24.8.0.49490-0+f338 all [installed,automatic]
ni-daqmx-fsl-libs/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-libs/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-mio-libs/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-mio/unknown,now 24.8.0.49497-0+f345 all [installed,automatic]
ni-daqmx-nicartenum-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nicdcc-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nicdr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nichenum-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nicmr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nicondr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nicsr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nidmxf-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nidsar-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-niesr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nifdr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nifresnelmbdc-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nifsl-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nihorbr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nilms-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nimsdr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-niraptr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-niscd-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nisdig-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nissr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nistc2-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nistc3r-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nistcr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nitior-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-niwfr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-nixsr-dkms/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-notices/unknown,now 24.8.0.49489-0+f337 all [installed,automatic]
ni-daqmx-scxi-libs/unknown,now 24.8.0.49497-0+f345 amd64 [installed,automatic]
ni-daqmx-switch-dkms/unknown,now 24.8.0.49498-0+f346 amd64 [installed,automatic]
ni-daqmx-switch-libs/unknown,now 24.8.0.49498-0+f346 amd64 [installed,automatic]
ni-daqmx-switch/unknown,now 24.8.0.49498-0+f346 all [installed,automatic]
ni-daqmx/unknown,now 24.8.0.49495-0+f343 all [installed]
ni-dim-dkms/unknown,now 24.8.0.49324-0+f172 amd64 [installed,automatic]
ni-dim-libs/unknown,now 24.8.0.49324-0+f172 amd64 [installed,automatic]
ni-dim-sysapi/unknown,now 24.8.0.49324-0+f172 amd64 [installed,automatic]
ni-dim/unknown,now 24.8.0.49324-0+f172 all [installed,automatic]
ni-euladepot/unknown,now 24.8.0.49571-0+f419 all [installed,automatic]
ni-hwcfg-utility/unknown,now 24.8.0.49495-0+f343 amd64 [installed]
ni-hwcu-hwsupport/unknown,now 24.8.0.49494-0+f342 amd64 [installed,automatic]
ni-hwcu-libs/unknown,now 24.8.0.49494-0+f342 amd64 [installed,automatic]
ni-iommu-notice/unknown,now 24.8.0.49244-0+f92 amd64 [installed,automatic]
ni-kal/unknown,now 24.8.0.49244-0+f92 all [installed,automatic]
ni-mdbg-dkms/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-mdbg-errors/unknown,now 24.8.0.49297-0+f145 all [installed,automatic]
ni-mdbg/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-mru-dkms/unknown,now 24.8.0.49324-0+f172 amd64 [installed,automatic]
ni-mru/unknown,now 24.8.0.49324-0+f172 all [installed,automatic]
ni-mxdf-dkms/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-mxdf-errors/unknown,now 24.8.0.49297-0+f145 all [installed,automatic]
ni-mxdf/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-mximanager-libs/unknown,now 24.8.0.49273-0+f121 amd64 [installed,automatic]
ni-mximanager-nicpciek-dkms/unknown,now 24.8.0.49269-0+f117 amd64 [installed,automatic]
ni-mximanager/unknown,now 24.8.0.49273-0+f121 all [installed,automatic]
ni-mxs/unknown,now 24.3.0.49261-0+f109 amd64 [installed,automatic]
ni-networkdiscoverysvc/unknown,now 24.8.0.49237-0+f85 amd64 [installed,automatic]
ni-openssl3-libs/unknown,now 24.8.0.49161-0+f9 amd64 [installed,automatic]
ni-orb-dkms/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-orb-errors/unknown,now 24.8.0.49297-0+f145 all [installed,automatic]
ni-orb-tools/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-orb/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-pal-dkms/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-pal-errors/unknown,now 24.8.0.49294-0+f142 all [installed,automatic]
ni-pal-support/unknown,now 24.8.0.49297-0+f145 all [installed,automatic]
ni-pal/unknown,now 24.8.0.49297-0+f145 amd64 [installed,automatic]
ni-pxi-tools/unknown,now 24.8.0.49267-0+f115 all [installed,automatic]
ni-pxihw-ni1045-dkms/unknown,now 24.8.0.49270-0+f118 amd64 [installed,automatic]
ni-pxihw-nicntdrv-dkms/unknown,now 24.8.0.49273-0+f121 amd64 [installed,automatic]
ni-pxihw-nimxi-dkms/unknown,now 24.8.0.49271-0+f119 amd64 [installed,automatic]
ni-pxihw-nipxicid-dkms/unknown,now 24.8.0.49273-0+f121 amd64 [installed,automatic]
ni-pxihw-nipxicmm-dkms/unknown,now 24.8.0.49270-0+f118 amd64 [installed,automatic]
ni-pxihw-nipxiethernet-dkms/unknown,now 24.8.0.49270-0+f118 amd64 [installed,automatic]
ni-pxihw-nipxim2-dkms/unknown,now 24.8.0.49270-0+f118 amd64 [installed,automatic]
ni-pxihw-nismbus-dkms/unknown,now 24.8.0.49273-0+f121 amd64 [installed,automatic]
ni-pxipf-errors/unknown,now 24.8.0.49267-0+f115 all [installed,automatic]
ni-pxipf-nipxifp-dkms/unknown,now 24.8.0.49275-0+f123 amd64 [installed,automatic]
ni-pxipf-nipxigp-dkms/unknown,now 24.8.0.49275-0+f123 amd64 [installed,automatic]
ni-pxipf-nipxirm-bin/unknown,now 24.8.0.49275-0+f123 amd64 [installed,automatic]
ni-pxipf-nipxirm-dkms/unknown,now 24.8.0.49275-0+f123 amd64 [installed,automatic]
ni-pxiplatformframework-data/unknown,now 24.8.0.49275-0+f123 all [installed,automatic]
ni-pxiplatformframework/unknown,now 24.8.0.49275-0+f123 all [installed,automatic]
ni-pxiplatformhwsupport-bin/unknown,now 24.8.0.49273-0+f121 amd64 [installed,automatic]
ni-pxiplatformhwsupport-data/unknown,now 24.8.0.49273-0+f121 all [installed,automatic]
ni-pxiplatformhwsupport-errors/unknown,now 24.8.0.49267-0+f115 all [installed,automatic]
ni-pxiplatformhwsupport-libs/unknown,now 24.8.0.49273-0+f121 amd64 [installed,automatic]
ni-pxiplatformhwsupport/unknown,now 24.8.0.49273-0+f121 all [installed,automatic]
ni-pxiplatformservices-bin/unknown,now 24.8.0.49275-0+f123 amd64 [installed,automatic]
ni-pxiplatformservices-data/unknown,now 24.8.0.49275-0+f123 all [installed,automatic]
ni-pxiplatformservices-libs/unknown,now 24.8.0.49275-0+f123 amd64 [installed,automatic]
ni-pxiplatformservices/unknown,now 24.8.0.49276-0+f124 all [installed,automatic]
ni-pxiplatformsoftware-errors/unknown,now 24.8.0.49267-0+f115 all [installed,automatic]
ni-pxisa-compliance/unknown,now 24.8.0.49267-0+f115 all [installed,automatic]
ni-qpxi-libs/unknown,now 24.8.0.49273-0+f121 amd64 [installed,automatic]
ni-qpxi/unknown,now 24.8.0.49273-0+f121 all [installed,automatic]
ni-resetniconfig/unknown,now 24.3.0.49261-0+f109 amd64 [installed,automatic]
ni-roco/unknown,now 24.8.0.49323-0+f171 amd64 [installed,automatic]
ni-routing-errors/unknown,now 24.8.0.49320-0+f168 all [installed,automatic]
ni-rtsi-libs/unknown,now 24.8.0.49490-0+f338 amd64 [installed,automatic]
ni-rtsi-pal-libs/unknown,now 24.8.0.49493-0+f341 amd64 [installed,automatic]
ni-service-locator/unknown,now 24.3.0.49347-0+f195 amd64 [installed,automatic]
ni-software-action-services/unknown,now 24.8.0.49237-0+f85 amd64 [installed,automatic]
ni-software-stream-noble/now 24.8.0.49572-0+f420 all [installed,local]
ni-switch-daqmx-config/unknown,now 24.8.0.49498-0+f346 amd64 [installed,automatic]
ni-syncdomain-service/unknown,now 24.8.0.49267-0+f115 amd64 [installed,automatic]
ni-sysapi/unknown,now 24.8.0.49237-0+f85 amd64 [installed,automatic]
ni-syscfg-runtime/unknown,now 24.8.0.49237-0+f85 amd64 [installed,automatic]
ni-targetcfg/unknown,now 24.8.0.49332-0+f180 amd64 [installed,automatic]
ni-wine-dotnet-runtime-80/unknown,now 24.8.0.49214-0+f62 amd64 [installed,automatic]
ni-wine-platform-support/unknown,now 24.8.0.49213-0+f61 amd64 [installed,automatic]
ni-wine/unknown,now 24.8.0.49214-0+f62 amd64 [installed,automatic]
ni-xlator/unknown,now 24.8.0.49244-0+f92 all [installed,automatic]
Message 1 of 1
(589 Views)
