Error -50251 using DAQmx. No idea what's the problem.
I'm getting "The specified software component is not available. The component was not loaded." Error number: -50251 when using DaqMX 7.3. I do a DAQmxResetDevice, a DAQmxCreateTask, and then a DAQmxCreateDOChan on a 6023E. What am I doing wrong?
(5,331 Views)
I just created a VI in which I do exactely what you are describing and I am not getting an error. However, there are a couple of things that you can try:
1. make sure that you are not using NI-DAQ traditional and NI-DAQmx on the same device at the same time. It is a good practice to always reset the device for traditional in MAX before running your VI.
2. a resource on the device cannot be used by two tasks at the same time. That can cause conflicts. For example, you cannot have two inpedent tasks using the counters.
I hope this answers your question. If not, please post more details about your application.
Serges
(5,331 Views)
Hi, Serges:
I got the the same trouble too. Followings are my codes:
long l_iRet ;
TaskHandle l_TaskHandle=0 ;
char l_sMsgTemp[255]="" ;
DAQmxCreateTask("", &l_TaskHandle ) ;
if( (l_iRet = DAQmxCreateAIVoltageChan( l_TaskHandle,
"Dev1/ai0",
DAQmx_Val_Diff,
-10.0,
10.0,
DAQmx_Val_Volts,
NULL
) ) !=0 )
// l_iRet = -50251
DAQmxGetErrorString( l_iRet, l_sMsgTemp, 255) ;
ShowMessage(l_sMsgTemp) ;
else
ShowMessage("Completed!!") ;
DAQmxClearTask(l_TaskHandle) ;
Besides that, I had tried "NIDAQmxResetDevice" and "NIDAQmxSelfCal" successfully.
The DAQ hardware I used: PCI 6032E
Driver version: 7.2
Programming tool: Borland C++ Builder
Could you please help me ...
Michael
(5,330 Views)
I too am having a similar problem with my code. I'm writing a DLL in Visual C++ 6.0 for use with my Borland C++ Builder 5. I've pretty much copied the (working) NI example code line for line when it comes to calling the NIDAQmx functions. While as I said the example works fine (compilied in Visual C++ 6.0) my Borland C++ written program and MS VC++ written DLL produce the error Status Code -50521.
Heres my code:
#include
//#include
//#include
#include "NIDAQmx.h"
#include "WriteDigChan_Fn.h"
#ifndef WINAPI
#define WINAPI __stdcall
#endif
#ifndef DAQmxErrChk
#define DAQmxErrChk(functionCall) {if (DAQmxFailed(error=(functionCall))) { goto Error; } }
#endif
extern "C"
int __decls
pec(dllexport) WINAPI initDO0()
int32 error=0;
TaskHandle taskHandle=0;
uInt8 data[8]={1,0,0,0,0,0,0,0};
char errBuff[2048]={'\0'};
DAQmxErrChk (Configure_WriteDigChan("Dev1/port0/line0:7",&taskHandle));
DAQmxErrChk (Start_WriteDigChan(taskHandle));
DAQmxErrChk (Write_WriteDigChan(taskHandle,data));
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 )
Stop_WriteDigChan(taskHandle);
MessageBox (NULL, errBuff, "DAQmx Error", NULL );
MessageBox (NULL, "Click OK to continue...", "DAQmx DLL", NULL );
return 0;
I'm using a PCI 6221 M series
NIDAQ 7.3
Any ideas would be appreciated..
Bergen
(5,330 Views)
I found the answer to the problem at another post:
click here to see post
basically it has to do with Borland Builder throwing floating point exceptions and can be overcome by adding the following to your code:
#include
myfunction(){
_control87(MCW_EM, MCW_EM);
Bergen
(5,332 Views)
Hi all,
I got a PCI 6024e card and as I want to test it with a Thermocouple two errors were displayed, which are error -50251 and error -200477. And as I run the self test, it wasn't running and instead of that, I also read some unknown ASCII character from panel test. Could anyone help me fix my problem ? Thanks in advance.
Jayadi Lukito
(4,749 Views)
I installed the NiDAQ 8.3 and the problems were solved. Just want to share to everyone.
(4,729 Views)
