Error -50303 Trying to read DAQmx Hardware
Using a runtime only PC, with a SCXI-1600 USB, and a SCXI-1102 Analog input card I am receiving a Error -50303. I can read the task fine using the Measurement and Automation Explorer.
(3,608 Views)
Hi ToddAN,
If it works in MAX, then it must be something in the code .
Can you please post your code so that I can take a look at it?
Faris
Bueller
(3,596 Views)
Faris,
I had Max working, then tried my .vi and found the -50303. After trying a few things and posting this on the forum I went back to make sure MAX was still working, but it was not. I believe could not see the hardware. Recycled power on the rack and that took care of it.
Thanks for looking into this for me.
Todd
(3,594 Views)
