Error -89125 occurred at DAQ Assistant
I use a setup with seven (7) PXIe-4330 and one PXIe-4353 simulated modules.
This is going to be a 'real' system, all modules will be installed in a PXIe-1078 Chassis (9 slots).
Chassis configuration will be:
slot1    : controller
slot2-8 : PXIe-4330
slot9    : PXIe-4353
I have created one task in NI MAX that I use to read all 56 AI channels from all 4330 modules.
When I run the task I get the following error "Error -89125 occurred at DAQ Assistant".
Please advice what could be wrong,
Thank you for your help!
Message 1 of 1
(1,140 Views)
