Error -89130 occurred at daqmxcfg_DAQmx Start Task.vi:1
I'm attempting to set up a cDAQ 9133 connected to a host computer.  I've reinstalled the drivers, reinstalled the devices and interfaces, and followed the steps outlined at http://digital.ni.com/public.nsf/allkb/61371556441E5FF68625730600775934 but I still see the same message.
Everything is brand new, just opened, never used before.  I can see the Remote System in MAX, I can see each of the devices (9215 and 9263), and everything passes the self-test.  9215 returns the error in the test panel written in the title, 9263 returns -89130 in the Test Panel (much less descriptive).  Everything is up to date, and the DAQmx driver is 14.5 on both the computer and the cDAQ.
Any thoughts or things I may have overlooked?  Are there any particular modules that need to be installed on the host computer for this to work that aren't part of the standard installation and wouldn't be included in the USB drive that came with the cDAQ?
(4,491 Views)
Hi ecf14!
I have a couple of questions regarding your setup.
Are you running Windows 7 or NI Linux Real-Time on the cDAQ?
If you are running NI Linux Real-Time, have you downloaded and installed the LabVIEW Real-Time module?
The device manual has some helpful troubleshooting steps to ensure that you have set up your device correctly.
http://www.ni.com/pdf/manuals/371800c.pdf
Mena S.
Applications Engineering
(4,414 Views)
