Error -89136 Connecting CtrOut to RTSI
I have a PCI-6052E that I would like to use as a trigger for sending CAN messages. I have attached a RTSI cable between my PCI-CAN board and my PCI-6052E, but when I map the CtrOut of the PCI-6052E to a RTSI channel, I receive an "Error -89136 occurred at DAQmx Connect Terminals.vi". MAX - Device Routes shows the connection between CtrOut and RTSI to be a direct route (green). So, why the error?
LabVIEW 8.2.1
DAQmx8.5.0f5
WinXP SP2
(3,179 Views)
It's working now.  I used "Browse..." instead of directly picking the channels from the drop downs and now it works. Smiley Surprised
(3,174 Views)
