Error code 200874
Hi ,
I am getting this error all of a sudden in a normally okay running program.
"Error -200874 occurred at DAQmx Write (Counter Time 1Chan 1Samp).vi
Possible reason(s):
DAQmx Write is supported for counter output channels only while the task is running.
To use DAQmx Write with the given task, invoke DAQmx Start prior to DAQmx Write.  To specify the low and/or high time while the task is not running, set DAQmx properties instead of invoking DAQmx Write.
Task Name: _unnamedTask<4>"
I am using the" autostart task"  functionality of the DAQmx .
But it started giving error .
Any help would be highly appreciated.
Regards
CLAD
Using Labview 5.1,6.1,7.1.8.0
(3,562 Views)
Hello labviewmission.
Thank you for contacting National Instruments.
This discussion forum asks the same question as the Discussion Forum that you created at another location:
Ed will answer your issue shortly and will be happy to help you until your issue is resolved.  However, please refrain from creating multiple discussion forum threads on the same topic.  Doing this causes organizational problems and makes our Discussion Forums much harder to search for other customers who have the same question that you do.  It also makes it hard for National Instruments to attend to all of its other Discussion Fourm threads in a timely manner if we are constantly answering the same question on multiple threads.  Please keep this in mind when posting in the future and we will continue providing you with the best possible support.
Have a great day!
Brian F
(3,530 Views)
Hi Brian,
I apologize for the double Post. When I did not get a reply for 2 days ,I thought may be I have posted my question on a wrong forum.
This was the only reason i posted my question not twice but thrice:mansad:
I really appreciate Ed and you for replying to my problems.
CLAD
(3,526 Views)
