Error codes defined in text file
I have created a new file for creating my user defined errors using tools>advanced>edit error codes and created a few new error definitons starting at 5000 thru 5003. I then save it and close the window, go back to my VI block diagram and while using the Error Cluster from Error.VI standard VI in LV 7.1, I inject a code 5000 into it and do not get my message to come out on the error out terminal.
What am I doing wrong here?
(4,322 Views)
You need to restart LabVIEW first as the help says. If you did this, did you create a file with the name prefix-errors.txt?
(4,319 Views)
can i edit this error text message to "Wrong input option", can i?
please...
Message Edited by marp84 on 08-05-2009 08:47 PM
(4,069 Views)
Sure but why don't you fix the program you wrote. The case statement is doing absolutely nothing. If 0 is selected, you still pass 0 to the simulator function. You can place the simulator  function inside the non-zero case or simply set the control so that 0 is not allowed.
Again, this is very basic stuff that you seem to have a hard time getting a grasp of.
And, please try to refrain from hijacking old and unrelated threads.
Message Edited by Dennis Knutson on 08-05-2009 08:57 PM
(4,065 Views)
nice thanks,but how i can change that error message cause i dont see the code of error message?
can you help me?
(4,060 Views)
First, you would need to find the actual error number. Then you would have to search through the error files, find the number, and replace the text. Look in \LabVIEW 8.x\resource\errors\English for the txt files that have the error codes and messages.
I would reallly, really prefer that you fix the program. What you are doing with the text is just a band-aid and since your program is so easy to fix, I don't understand why you are so reluctant to do so. DO THE RIGHT THING!
(4,046 Views)
okay i'll fix it.tanx for your help.
(4,035 Views)
