Error creating TASK
Hi, I recently updated my system to version 2026 Q1 (LV and all related tools, including DAQmx, NIMAX, VISA, etc.). I was previously using LV 2013 with all related tools aligned, everything runs on a Windows 11 workstation.
I primarily use an NI 9184 chassis with three modules installed: NI 9401, NI 9403, and NI 9205, but the same problem occurs with an NI 9185 chassis as well.
I'm experiencing very strange behavior when importing a cDAQ TASKs within NI-MAX.
I'm attaching the NI-MAX configuration file (in .ini format).
After importing the .ini file, if I check one of the output task, I find this:
NIMAX task propertyNIMAX task property
the error details report this:
"One or more of the inputs to this step are not selected. Insert a step before this step which has an output that matches the type of signal this step requires."
I'm really having trouble understanding what this means because:
1) I'm creating an output task and want to assign a value at runtime (in LabVIEW), so why would I connect another input/output to this channel?
2) It's impossible to follow this hint... I can't add an input step in the same task as an output task; adding a second output step makes no sense (and doesn't work).
3) The NI-MAX CDAQ task creation/import with the same exact features worked with all previous versions of NI-MAX, DAQmx, etc. (with the same hardware).
P.S. The same error is reported even if I create the activity manually, so it shouldn't be a problem with the .ini file format.
(644 Views)
The issue is fixed by reparing NI DAQmx install.
(571 Views)
