Error of 'niModInst Close ...' for 5133
Originally the program works fine, but after change something unrelated to DAQ, it cannnot work any more.
Please see the attached screenshot for the error.
The NIScope still can run.
Any suggestion, thanks.
(3,120 Views)
Hi alex,
Can I get more information from you:
1. LabVIEW version
2. Is your application is in EXE form? or still in VI form?
3. If you can post the VIs, maybe I can be more help
Sincerely,
Krisna Wisnu
72378
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
(3,105 Views)
Solved after recompile on another pc.
(3,101 Views)
