Error when using DAQmxBaseReadBinaryI16 on Linux
I am using DAQmx-base (C library) on Linux with a USB-6009 device. When I am acquiring data
using DAQmxBaseReadAnalogF64() (the code is based on the example contAcquireNChan.c)
everything works, but when I am using DAQmxBaseReadBinaryI16() the following error
happens:
DAQmxBase Error: Value passed to the Task/Channels In control is invalid.
Everything is the same just the ...AnalogF64 is replaced by the ...BinaryI16 function call
(of course the buffer used for storing the data was also changed from float64 to in16).
Does anyone know what settings (or missing settings) result in this error?
Every explanation or pointer to some documentation is welcome. I already checked the
C reference HTML documentation coming with DAQmx-base without success.
Raphael
(3,599 Views)
I have the same problem with that function on windows and NIUSB 6008.
Some people say there's some bugs with NIDAQmxbase...
http://forums.ni.com/ni/board/message?board.id=250&message.id=11529&query.id=17263#M11529
or search
DaqmxbasereadanalogF64 to see some threads about reading datas with NIUSB.
(3,581 Views)
happens:
Raphael
From the ReadMe file for DAQmx Base on Macintosh OS X:
NI USB-9211
*Analog Input
-Multi-channel, multi-sample read (scaled)
-Multi-channel, single sample read (scaled)
NI USB-9215
*Analog Input
NI USB-6008/9
*Analog Input
-Digital start triggering
Raw input simply isn't supported for the USB devices. I would guess that the situation for Linux is the same, since DAQmx Base is based on Labview code in order to achieve cross-platform portability. See the thread
http://forums.ni.com/ni/board/message?board.id=250&message.id=11873
and, for a slightly different problem:
http://forums.ni.com/ni/board/message?board.id=250&message.id=11963
Be sure to read down to where there is a message indicating that support for USB devices is planned for NI-DAQmx. Of course, that won't help on Macintosh and Linux.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,573 Views)
