Error while executing the Labview into my PDA
Hi NI,
I'm having problem while i execute my Labview into my PDA. The error message is "Error Executing. The application may not have been executed.
And there seems to be another problem. When i operate my PDA or slot the DAQ card into my PDA, an unknown message pops out and says "Unrecognized Card - Enter the name of the device driver for this card.For information, see the card manufacturer's documentation.Could the unrecognized card be DAQ NI CF-6004 card? If yes, what's the name of the device so i can input it into the PDA.
Thanks alot
From,
UC a.k.a Gabriel
(6,321 Views)
Hi Gabriel,
Do you have the DAQmx base driver installed? This driver is required to program the CF-6004. If the driver is not installed, the card will not be recognized and this could cause your error. Also, did you install the driver on the PDA as well? (Start >> Programs >> National Instruments >> NI-DAQmx Base >> Windows Mobile and CE Driver Installation ) You can check to make sure the drivers are installed and card is recognized by using the ‘NI-DAQmx base list devices’ utility to show the 6004.
If errors are still occurring, posting the error code and screenshots would be very helpful.
David L.
Systems Engineering
(6,279 Views)
Hi Daryl,
Problems solved.
Thanks for your help.
(5,708 Views)
