Error while starting two temperature analog task on two différent boards
Hello
I am developping a acquisition software for two NI PCI-6229 (only simulated into Max for the moment) under Visual Studio 2005.
I have configured two analog acquisition tasks on the 2 devices separatly (different handle...etc) with several thermocouple channels.
The initialisation and the launching of the task seem to work fine. But when i want to read my values, it works on the first device but not on the second one. It says me that my task has not been started.
"Measurements: No data is available to read, because no acquisition has been started.
Start the acquisition before attempting to read data, either explicitly or by enabling auto start and stop.
Task Name: _unnamedTask<4>
Status Code: -200286"    char [2048]"
The funny thing of the problem, is that everything goes right when i add a classical analogical channel in my tasks. I can't get my values simulated by Max.
Is there anything that can explain such a strange behaviour?
Thank you
DanY
Code extracted from my application:
//Configuration
DAQmxErrChk(DAQmxCreateTask("",&thAcqAna))
if(Ana)
    DAQmxErrChk(DAQmxCreateAIVoltageChan (thAcqAna, strNomVoie, "",iTabConfig[VoieTemp.m_nConfig],
                            VoieTemp.m_flMin,VoieTemp.m_flMax,DAQmx_Val_Volts,NULL))
if(Temp)
    DAQmxCreateAIThrmcplChan (thAcqAna, strNomVoie, "",VoieTemp.m_flMin,VoieTemp.m_flMax,
                                        DAQmx_Val_DegC,m_nTypeThermo,DAQmx_Val_BuiltIn,0.0,"")
DAQmxErrChk(DAQmxCfgSampClkTiming(thAcqAna,"",RATE_ACQ_NI,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1));
//Starting the task
DAQmxErrChk(DAQmxStartTask(thAcqAna));
//Reading the values
DAQmxErrChk(DAQmxSetReadAttribute (thAcqAna, DAQmx_Read_RelativeTo,
                       DAQmx_Val_MostRecentSamp))
DAQmxErrChk(DAQmxReadAnalogF64(thAcqAna,1,1.0,DAQmx_Val_GroupByChannel,&(*m_pfMesuresAna.begin()),                 <- get the error here
                        m_pfMesuresAna.size(),&nNbMesLu,NULL))
(3,475 Views)
Anyone is inspired by my problem?!
I made more tests on it and my first analysis didn't seems to be right.
In fact, no acquisition on any device can be read when i put 'only' some thermocouple channels.
The DAQmxStartTask function doesn't return any error, it's only when i want to read my values thats the DAQmxGetExtendedErrorInfo says me that i haven't start my task.
Moreover, when i detect the error on the reading, i want to delete the task (DAQmxStopTask + DAQmxClearTask + handle=0) but the application get stuck into the DAQmxStopTask, all the threads working otherwise.
To sum up, i can have tasks with only pure analogical channels, analogical + thermocouple channels but not with only thermocouple channels.
Is anyone have already encontered that problem or is it my task configuration that is wrong?
(3,454 Views)
Hi DanY,
What happens if you put a DAQmxErrChk() around DAQmxCreateAIThrmcplChan()?
Are you using the same code for both devices?
Brad
Brad Keryan
NI R&D
(3,443 Views)
Hello Brad, thanks for helping me.
The problem doesn't seem to come from the fact that i got 2 cards... I simplify my configuration to investigate it more precisely.
I only put one Thermocouple channel on the first device...
I configure it as said before, everything goes right.
I start the task -> no error
I modify the reading function to get more informations:
        DAQmxErrChk(DAQmxGetReadAttribute(thAcqAna,DAQmx_Read_AvailSampPerChan,&nNbMesLu));
        if(nNbMesLu > 0)
                            m_pfMesuresAna.size(),&nNbMesLu,NULL));
        else
I never get an available sample so i try to start the task (as the error says me before that it wasn't started) and I get this:
>"Measurements: Specified operation cannot be performed while the task is running.
>Task Name: _unnamedTask<0>
>Status Code: -200479"    char [2048]
There is a incoherence in the error messages -> When I want to read the samples it says the task is not running
        -> When i want to start the task it says the task is already running
Smiley Surprised
To test a working situation, I add a classical analog channel in first position (1 analog + 1 thermocouple)
This code doesn't work anymore, i got somes "available samples per channel" at the first cycle but not at the next ones.
That is perhaps due to the fact I only read the most recent ones, when i remove the test on the number of available sample, i get some values at each cycle...
But that doesn't explain me why i haven't any samples when i got only one Thermocouple channel.
Thanks  for help
DanY
Message Edité par danydan27 le 02-04-2008 03:30 AM
Message Edité par danydan27 le 02-04-2008 03:31 AM
(3,422 Views)
