Error with DAQmx assistant after update to LabVIEW 2010
I have recently updated LabVIEW from 2009Sp1 to 2010. Now I'm working with a project in LabVIEW 2009, in which I have configured a DAQmx task for data aquisition. If I try to open this task, I get the attached error message (it is in German). I get the same error message, if I try to create a new task with analog input -> voltage.
What's wrong here?
Marc
CLD
(3,209 Views)
Hello Marc,
I would like to see more details, where and how did you create the DAQmx task, in LabVIEW itself or in Measurement & Automation Explorer (MAX)?
Could you provide:
  • your project / VI
  • Measurement & Automation Explorer (MAX) technical report
  • LabVIEW failure log: C:\%USERPROFILE%\Documents\LabVIEW Data\lvfailurelog
  • Do you use real hardware?
(3,156 Views)
I just wanted to bundle the data and upload it to the forum, but for reasons unknown the problem is gone. Perhaps I just forgot the golden rule to reboot Windows, if something does not work...
Anyway, problem solved, thread closed, thanks for your help.
Marc
CLD
(3,108 Views)
