Ethernet Distributed DIO Modules
I have used the Advantech ADAM-6000 DIO Modules but they are not well supported for LabVIEW. Any other 16-32 bit distributed I/O like this but integrates well with LabVIEW?
(3,167 Views)
Hello FM Kautz,
It sounds that you would benefit from Compact FieldPoint.  This is the multifunction DAQ Forum, it would be beneficial if you posted this question here on the FieldPoint Forum.
In order to get 16 channels of DI/O I would use the NI cFP-DIO-550.  If you want 32 channels of DI, I would use the NI cFP-DI-304.
Respectfully,
Rob F
Test Engineer
Condition Measurements
(3,155 Views)
