Example .NET code for Digital write and read
I am looking for example NI DAQmx C# .NET codes for reading and writing to digital ports on a DAQ. I am unable to find the example codes in C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0.
Thanks in advance.
(3,731 Views)
It sounds like you did not add text based support during your driver installation. Go to Windows Add/Remove programs>National Instruments then check the DAQmx driver from the software list. Next select "Modify" to make sure you add text based code support. The following examples should be available.
(3,725 Views)
