Example for sequential sampling of analog channels ?!
With LabView, I have tried to sample in parallel 24 channels with SCB-68, and to export the data as an array of doubles. (to the .dll interface)
However, I have problems with crosstalk on channels. Due to the complexity of the setup, my intention is to sample every channel separately in order to avoid the crosstalk,
and in iterated steps to fulfil the array with values of the separately sampled channels. And at the end to make the array available (to the .dll interface).
Generally I am aware that I will have some delays, but still I expect that virtually I will achieve fast acquaintance of 24 values in array.
Does anybody have an example, how can I achieve this iterated sampling of list of channels, and at the end of the loop to have an array filled with new sampled values from all the channels together (in that way simulating the multiple channel sampling)?
Message 1 of 1
(2,888 Views)
