Example program acquireNScans-AnlgStart fails at call DAQmxBaseCfgAnlgEdgeStartTrig with Error -200428
Using USB-6009, DAQmx Base 2.1, on Mac OS X 10.5.
Seems like DAQmxBaseCfgAnlgEdgeStartTrig API does not work; even the example code shipped with this release does not pass:
./acquireNScans-AnlgStart
LoadRuntime: MainBundle
CFBundle 0x107550 (executable, loaded)
_CompatibleWithLabVIEWVersion: linkedAgainst: 08208002
_CompatibleWithLabVIEWVersion: result= false, mgErr= 1, theActualVersion= 00000000
_CompatibleWithLabVIEWVersion: linkedAgainst: deadbeef
_CompatibleWithLabVIEWVersion: Reseting Linked Against
_CompatibleWithLabVIEWVersion: result= true, mgErr= 0, theActualVersion= 00000000
com.ni.LabVIEW.dll.nidaqmxbaselv
CFBundle 0x116020 (framework, loaded)
{type = 15, string = file://localhost/Library/Frameworks/nidaqmxbaselv.framework/, base = (null)}
Macintosh HD:Library:Frameworks:nidaqmxbaselv.framework
2008-03-18 16:02:14.963 acquireNScans-AnlgStart[963:10b] Error loading /Library/Frameworks/LabVIEW 8.2 Runtime.framework/resource/nitaglv.framework/nitaglv: dlopen(/Library/Frameworks/LabVIEW 8.2 Runtime.framework/resource/nitaglv.framework/nitaglv, 265): no suitable image found. Did find:
/Library/Frameworks/LabVIEW 8.2 Runtime.framework/resource/nitaglv.framework/nitaglv: mach-o, but wrong architecture
DAQmxBase Error: Value passed to the Task/Channels In control is invalid.
(3,247 Views)
Hey Benjamin,
The USB-6009 does not support analog triggering. Instead you could use a digital trigger. You can see the document below for triggering compatibility for different devices.
Trigger Types for M Series, E Series and B Series Boards
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIhASAU&l=en-US
Chris Delvizis
(3,237 Views)
