Exhausting voltage states
Hi jm,
From your follow up on the other forum it looks like you've got what you need--if you have any questions don't hesitate to post back!
Best Regards,
John
John Passiak
Message 11 of 20
(2,013 Views)
John,
It looks like the last cycle of your raster has extra points on it - as many extra as the number of Y steps.  For the X scan, these are being generated by the outer For Loop's Index counter auto-indexed at the top right of that outer For Loop.  I did not see how or why they were being generated for the Y scan, so I modified the code for my use by simply extracting a sub-set of the array that is (X Number of Steps * Y Number of Steps) long.  This results in the last point of the Y raster being at Y Minimum (and only one such point at its end that is that value) and the last X point remaining at the X Maximum (instead of ramping down to X Minimum).  Is there an intended reason these extra points are there ?
Steve
Message Edited by SteveP on 09-11-2009 10:16 AM
Message 12 of 20
(1,985 Views)
Hi Steve,
Thanks for the feedback!  The extra points were intended to "reset" the scanner back to the original position.  I didn't want to instantly transition from the maximum to minimum value since this could be problematic when interacting with actual hardware.  This code was written for a specific application so more likely than not some modifications will need to be made depending on your exact requirements.  I hope it at least provided a good starting point for your application!
Best Regards,
John
John Passiak
Message 13 of 20
(1,980 Views)
Could you point out where in the code the extra points are being added to the Y raster ?  I could then eliminate them there rather than after they have been generated by using an array subset.
Thanks - yes - it is a good starting point.
Message 14 of 20
(1,977 Views)
Hi Steve,
I modified the code a bit so there's now a front panel button to enable/disable the reset at the end of the scan.  Here's the link again for your convenience:
Generate 2D Raster Pattern in LabVIEW
-John
John Passiak
Message 15 of 20
(1,962 Views)
John,
A subtle note is that enabling Reset Y at End of Scan? results in the Y array size being larger than X.  When they are combined with Build Array, the end of the X array is filled with a value of 0.  If X Minimum was set to something other than 0, that results in those extra points having a different value than the last X point in the raster.
Steve
Message 16 of 20
(1,956 Views)
Hey Steve,
Good catch--I fixed the behavior byadding the correct number of samples to the X array so it is not coerced.
-John
John Passiak
Message 17 of 20
(1,934 Views)
John,
Now the Reset button has been removed as well as the plot.  Is X being filled with 0 instead of being filled with X Minimum ?
Steve
Message 18 of 20
(1,929 Views)
Hi Steve,
Did you download the new version here?  It seems to work fine on my end.  X is being filled with 0 initially, but X_Min is added to the entire array after this takes place so X will remain at X_Min at the end of the generation.
-John
John Passiak
Message 19 of 20
(1,924 Views)
if was looking at the sub-VI.  The latest version looks fine.
Message 20 of 20
(1,921 Views)
