Experiment problem
Hi AGale,
I'm not sure why you would have to change a filename during the conversion process.  Was the renamed VI from the ZIP file that I posted?  If so, can you just re-download the ZIP file that I posted, and then check the name in there?  Or how about downloading it again and then trying to copy and paste the VIs from the .llb file into its own directory structure?  There definitely will not be any renaming necessary for this procedure.
What exactly is going on with the Linear Fit.vi?
Ed W.
Message 21 of 21
(764 Views)
