Multifunction DAQ
Export Sample Clock to external instrument from 6723
I'm a relatively new user to PCI DAQ cards.
I have a 6723 A/O board in a PXI Express 1033 chassis and I need to generate a TTL signal to trigger some external test elecrtonics (an Agilent optical power meter) sychronised to the voltage sweeps generated from the 6723. Looking through the manual I think I need to 'export the sample clock'. It further tells me I can do this by setting the PFI5 channel to output mode instead of the default input mode.My problem is I don't know how to change the setting!
I am controlling the card using VB.net via DAQmx drivers.
Any suggests would be most gratefully received,
Message 1 of 1
(2,789 Views)
