External Power Supply for NI-9237 Strain Gauge Module
I want to use a 10Vdc, 1A, power supply to provide external bridge excitation to 4 load cells connected to a NI-9237 strain gauge module.
Can anybody recommend a unit, that can be DIN rail mounted within a standard NI cRio enclosure, for the job?
Cheers
Andy
(3,565 Views)
Hi Andy,
As you probably know, National Instruments does not manufacture or sell DIM power supplies however there are companies that do produce DIM power supplies that will do what you require. A company called Phoenix Contact (http://www.phoenixcontact.co.uk/) does sell DIM power supplies so it might be worth speaking to them to see if they have anything that meets your needs.
Sorry I can't be of any more direct assistance on the matter,
Ian C
National Instruments UK & Ireland
(3,548 Views)
Ian
Thanks for the help.
Andy
(3,545 Views)
