External clock - analog out 6225 + NI_DAQmxbase
I have a little acquisition/output routine in c (OS X, PCi-6225) that requires an external 10kHz clock + trigger. For testing, I have been using
clockSource[] = "OnboardClock"
 for both input and output tasks.
I have a 10Khz clock coming in on PFI1,   when I set
clockSource[] = "/Dev1/PFI1"
the output task fails but the input task works.
Below are  the relevant snippets, I have tried combinations of trigger and clock edge choices.
Alex
#include <stdio.h>
#include "idl_export.h"        /* IDL external definitions */
#include "NIDAQmxBase.h"
#include <stdio.h>
// Timing parameters
    char        clockSource[] = "OnboardClock";
    uInt64      samplesPerChan = 2500;
    float64     sampleRate = 10000.0;
// Triggering parameters
    char        triggerSource[] = "/Dev1/PFI0";
    uInt32      triggerSlope = DAQmx_Val_RisingSlope;
//**** SETUP OUTPUT ******
 // Channel parameters
    char        outputChan[] = "/Dev1/ao0";
    // Data write parameters
    float64     outputData[bufferSize];
    int32       pointsWritten;
   if (!DAQmxBaseCreateTask("",outputTask))
        DAQmxBaseCreateAOVoltageChan(*outputTask,outputChan,"",min,max,DAQmx_Val_Volts,NULL);
        DAQmxBaseCfgSampClkTiming(*outputTask,clockSource,sampleRate,DAQmx_Val_Falling,DAQmx_Val_FiniteSamps,samplesPerChan);
        DAQmxBaseCfgDigEdgeStartTrig(*outputTask,triggerSource,triggerSlope);
//        fprintf(fp,"  pointer to outputTask = %i, value of outputTask = %i \r\n",outputTask, *outputTask);
int arm_digitizer_natural(TaskHandle *inputTask,TaskHandle *outputTask,float64 *writeArray,float64 *readArray )
    int32 i;
       double input,output =0;
    char errorstr[512];
    uInt32 errBuffCount;
    float64     data[bufferSize];
    float64     timeout = 900.0;
    // Data read parameters
    int32 pointsToRead = (uInt32)2500 *25;
    int32 pointsRead;
    int32 readResult;
    DAQmxBaseStartTask(*outputTask);
    DAQmxBaseWriteAnalogF64(*outputTask,samplesPerChan,0,timeout,DAQmx_Val_GroupByChannel,writeArray,&pointsWritten,NULL);
    DAQmxBaseStartTask(*inputTask);
    readResult = DAQmxBaseReadAnalogF64(*inputTask,pointsToRead,timeout,DAQmx_Val_GroupByChannel,readArray,pointsToRead,&pointsRead,NULL);
    DAQmxBaseStopTask(*inputTask);
    DAQmxBaseStopTask(*outputTask);
    return 1;
(3,073 Views)
What is the actual error that you get?  Is there an error number associated with the error that you receive.
Are you using both the commands in the same program?  I am assuming you meant triggerSource for the PFI1 line.
Once you give me a few more details on the error that you are receiving, I will be able to help you better.
Raajit L
(3,023 Views)
Hi-
Thanks for replying.Chris Kinvig at NI Apps got back last week and pointed out that I started the task before writing data to the output. Once I reversed those lines, it worked. That worked before with an internal clock, but not an external one. I'll admit that writing to the output buffer , then starting the task is inherently more sensible, but why did it work before ? Doesn't matter, it's fine now.
thanks
Alex
(3,019 Views)
