External convert samples don't work for PCI-6111
I'm trying to use an external convert signal for a single channel acquire on a PCI-6111. I'm using VB. The supplied example (DAQSingleBufExtConv_Eseries) doesn't work. I get error # -10003 at the DAQ_Config call. I have tried all sorts of combinations of DAQ_Config and Select_Signal, but have no success.
Why is this so? I'm using NI-DAQ 6.9.1.
(2,677 Views)
Dave,
The Traditional NI-DAQ Function Reference Help for the DAQ_Config function contains the following comment:
Note: (61XX devices only) The only allowed values for extConv are 0 and 2. The conversions occur simultaneously for all channels and are controlled by the scan interval.
The Traditional NI-DAQ Function Reference Help is available in the following location:
Start >> Programs >> National Instruments >> NI-DAQ >> Traditional NI-DAQ Function Reference Help
So, you will want to assign the extConv parameter a value of 2 and use the Select_Signal function to route the signal accordingly.
Good luck with your application.
Spencer S.
(2,677 Views)
Thanks. It works fine now. (Perhaps I should read the notes more carefully in future!!!)
Dave.
(2,677 Views)
