External voltage excitation NI 9237
I'm using a CompactDAQ Chassis with 2 NI 9237 modules for strain gauge measurements.
The maximum excitation voltage of my gauges is limited to 1V...
The 9237 supports internal voltages from 2,5 to 10V.
I want to connect an external voltage supply. Now I found the restrictions of 2V-10V in the datasheet for external devices. Is there any way of getting my 1V voltage into this system?
Karsten
(4,187 Views)
Hi Karsten,
When external excitation is enabled on the NI-9237, the excitation ±terminals (pins 6 and 7) disconnect from the internal cDAQ backplanesource and connect to the 4 terminal EX ± AI Bridge on the front of thedevice.  With external excitation enabled, a 2-10 volt external powersupply needs to be connected in order to provide excitation.
If the external power supply voltage is less than 2 volts,you will see inconsistent voltages measured across pins 6 and 7 (EX±).  For example, with 0.5 volt excitation applied, the measuredvoltage might be 4.5 volts.  There is no workaround for this; theminimum voltage the 9237 accepts is 2 volts.  This is a constraintplaced on us by the ADC.
regards,
Tobias
(4,174 Views)
I also tried to work with 2V external source... but then I get about 5 V between Pin 6 and 7? How could this happen?
I connected the external source to 2 of the 4 ex-Pins
I switched the settings in the vi to external source and excitation value = 2
(4,167 Views)
Karsten,
this happens because of the limiation of the ADC in the NI-9237 which requires at least 2V.
regards
Tobias Daub
(4,149 Views)
OK ...
up to 2V - I understand... but
why does it happen with my external source with 2V? Or with 2.1 V or 2.2 V?
The described effect disappears after an external voltage of 2.5V
(4,147 Views)
