EzAnalyst thinks I have a Wavebook instead of Zonicbook
I am having difficulty getting the hardware and software to get along.  Based on the test from teh DAQConfig app, the computer and Zonicbook are communicating correctly.  However, when I open up EzAnalyst, it cannot find the configuration for the Zonicbook and, for some reason, defaults to a Wavebook instead.  The system worked fine the last time I performed data collection in the field (about 2 months ago) and had not been operated since.
(3,086 Views)
TyReed,
This symptom typically results from an internal connection problem in the ZonicBook, where the IEPE signal conditioning board looses connection with the main A/D board.  The hardware reverts to 'thinking' it is a Wavebook.  I would suggest that the ZonicBook be returned for servicing / repair.
Dave McFate
David J. McFate, CVA Cat. III
Staff Systems Engineer
Sound & Vibration Group
dave.mcfate@ni.com
(3,064 Views)
