FPGA and SCB68
Hai... hope somebody clear my doubt.... i am using PCI7830R DAQ in my PC... and Connecter block SCB 68 hardware.... i devolped a VI in Project Explorer Methode...to check the digital pins in DAQ and hardware....while i running a VI without connecting LED in hard ware section, all LED in ON condition in frontpanels of both sub and Host VI ....but after i wired a bread board with SCB68 and placed LED in breadboard (to check 7830R card and SCB68 mapping) respectively to the pin numbers of DAQ( eg: DIO0 pin number in DAQ and SCB68 is36 & 2...i take a wire from 36 pin from SCB68 as positive and 2nd pin as negative , connect it to bread board where i placed LED...)....the prob is just for testing i wired only one LED and run VI after this settings...the particular LED is not blinking in both hardware and Front panel of VI .....why this prob? whether i have to placed any resistor in bread board? ..
(2,846 Views)
Alieas,
Hello! In the future, Please do not post the same question in multiple locations.
Duplicate Post
Ben Sisney
FlexRIO V&V Engineer
(2,834 Views)
